I have another problem with the Filename > Tag conversion. My filenames look like this:
01 oranje boven - De Euromaster.mp3
02 ba da da (rotterdam mix) - The Ultimate Seduction.mp3
03 ik wil dansen - Underground nation Of Rotterdam.mp3
I want them the other way round, but the entry in freedb was wrapped. So I changed the names by using the Tag > Filename converter and then I want to change the tags using the Filename > Tag converter. The filter I used is
%track% %title% - %interpret%
so everything should go well. But even if mp3tag shows me the right assignments in the preview it doesn't assign the interpret tag. It's still empty. I reproduced it with the current development version.
Are there some ideas to solve this problem?
edit:
I found the solution, I have to use the artist tag. But do I have now interpret - tags in my mp3 files after trying this?
