Underlined red, where comes spaces.
If this is not a bug (then how to remove spaces?), please move to proper section.
Most probably there are extra spaces in those fields themselves that you cannot see them from the display.
This is the code I used in my Actions script.
[#13]
T=4
F=_ALL
1=^\\\\s+
2=
3=0
[#14]
T=4
F=_ALL
1=\\\\s+$
2=
3=0
It is used to trim all the trailing spaces (front and end) from any field.
Thank you.
Please refer to the attachment.
Hope the screenshot helps you understand better what I mean. Those in the red box is the one which I'm talking about.
Thank you.
My bad - it is not a bug, but something wrong with this one album.
For admin: Please delete this topic or move to proper section.
