The CD player in my car can play mp3 files, but can only read ID3v1 tags. All of my tunes are currently in ID3v2.
Is there a way for me to convert the files to v1 tags before burning them onto CD?
Go to Options > Tags > Mpeg
Select
Write: ID3v1 and ID3v2
Remove: ID3v2
Then use Ctrl+S (Save Tag) on your files, now they have ID3v1 and ID3v2
You can also try the 3 different ID3v2 options, maybe the player reads iso 8859-1 or it skips utf-8
If you need to remove the ID3v2 tag, then use Ctrl+R (Remove Tag)
If you remove the ID3v2 tag, you might lose tag information since ID3v1 has limits.
