I'm using the "Convert tag to Filename" command with the following: $validate(%title%,_)
This works great, except occasionally it will generate filenames beginning with a period character which get ignored by both Foobar and Kodi as "hidden" system files.
If the first character of the filename is a period, is there a way to have it converted to an underscore?
there is not automatism as the dot is a legal character for filenames.
But you could enclose the whole expression for the converter into a $replace() function, e.g.
