I upload my file to spotify , but Japanese file name cannot be correctly shown
So I need to convert them to ID3v2.3 UTF-16
How to covert my file(wav and flac) to UTF-16 , and I dont want to re enter file’s title, artist, image…
And I dont know how to corrected set option>Mpeg
If you load your Japanese music files into Mp3tag, do you see the TITLE, ARTIST with all the correct characters?
To save them in ID3v2.3 UTF-16 you can set the Mp3tag Write-Options for ID3v2 accordingly:
You can find the details in the documentation.
Please note that the encoding settings only apply to mp files.
Flac files get tags encoded in UTF-8
See here:
BTW: the tag encoding has nothing to do with the filenames.
thank you, I found the problem
flac can be correctly loaded
only wav file error, so I think problem is on spotify with wav instead of UTF-8 or UTF-16…
