Converting %ARTIST% names
Hello everybody,
Many tracks in my collection contains two or more artist names, always separated by commas, in %ARTIST% field, as following: Neil Diamond, Carol King.
Is there a way to convert %ARTIST% into Neil Diamond (i.e. first artist name), putting Carol King (i.e. second or more following artist names) into %ALBUMARTIST% field?
Thank you
Ian
Are you absolutely sure that you don't have ARTIST names with a comma INSIDE the name, like many group names (i.e. "Emerson, Lake & Palmer" or "Crosby, Stills, Nash & Young)?
No, it's not my case.
Try an action of the type "Guess value"
Source: $regexp(%artist%,'(.*), (.*)',$1==$2)
Target format string: %artist%==%albumartist%
It doesn't work.
I use the italian MP3Tag version and here you can find a screenshot of how I arranged your tip; probably I've misunderstood your suggestion...
"caratteri jolly" translates into "place holder character" with google translate ...
The action I suggested should be something like "import tag field" or "import data".
I've got the proper option ("Valori corretti" in italian)!
Thank you very much!
immagine
Just as a side note:
You can always switch the language in Mp3tag in File -> Options -> Language.
This way you can add such an action with the suggested english names and then switch back to your (Italian) GUI language.
