I'd like to save the original filename into %comment% before renaming the file with my scheme.
The comment-Field already has a text string which should stay there so that the filename should be appended to this text.
Can this be done?
Thx
And, of course: Thank you for this great program, I use it for years together with foobar2000.
Thank you for the fast reply, Ohrenkino.
You were faster than my edit in which I precised that the old %comment% -value should not be wiped out, sorry.
