who can help me on the command needed to copy part of the filename to title and artist.
e.g. FILENAME = 01 - Come Together - Beatles to TITLE Come Together ARTIS Beatles
Many Thanks!
Many Thanks!
use the converter Filename - Tag
Enter a mask with variables for the fields. Enter %dummy% for any piece of data you don't want.
For your example:
%dummy% - %title% - %artist%
of if you also want the leading number as track number:
%track% - %title% - %artist%
Gee, that's fast and simple (when you once know it
Many thanks!
Hi today-joiner Bit Hacker.
Hm ... what did you learn about disabled buttons in dialogs?
What circumstances can cause a button to be greyed out?
Look at the given file name and look at the given format string.
Make a visual comparison of the format of both strings.
Does the format match?
DD.20121125.1504.CET
Never mind. Solved the problem.
Yes, the filename only had 'Artist' and 'Title' in it but the format string had %album% tag in it, which was causing the OK button disabled.
