I know this is going to be simple but I have been searchin the FAQ and forum for an hour and what I have tried isn't working. I want to copy the first 2 characters from the filename to the discnumber.
Action: Format value
... or ... Converter: Tag - Tag
Field: DISCNUMBER (fetch two leading characters)
Value/Format string: $left(%_filename%,2)
... or ... (fetch two leading characters)
Value/Format string: $reverse($right($reverse(%_filename%),2))
... or ... (fetch two leading digits)
Value/Format string: $regexp(%_filename%,'^(\d\d).+$','$1')
... or ... (fetch all leading digits)
Value/Format string: $regexp(%_filename%,'^(\d+).+$','$1')
