Copy portion of filename to RELEASETIME
I have a bunch of files named thusly: AA1_2008_01_01.mp3 to AA128_2008_05_08.mp3.
I want to use the date from the filename and copy it into the RELEASETIME tag with the format:
2008-01-01T12:00:00Z
Is this possible?
Thanks!
It is possible using Mp3tag's Convert > Actions feature :slight_smile:
Action #1:
Action type: Guess values
Source format: %filename%
Guessing pattern: %dummy%
%RELEASETIME%
Action #2:
Action type: Format value
Field: RELEASETIME
Formatstring: $replace(%RELEASETIME%,_,-)T12:00:00Z
Thank you! That works perfectly and saves me a lot of typing :smiley:
