Copy Sort Composer tags to Composer
Is there any way to batch copy the data from the Sort Composer field to the Composer field? I’ve looked all through the help site and can’t figure it out. There appears to be a Tag to Tag function and I am able to select the COMPOSERSORT column but then I want to be able to copy that field to the Composer field and I’m not sure how to do it — or if it’s even possible.
