Copy Tag to Filename, Keep Original
I really like the copy tag to filename feature in MP3Tag, I use it cause the formatting helps organize my music unto my flash drive for my cd player in my car. But I was wondering if it was possible to use that feature, but instead of moving the files into folders and renaming them, just copy em. That way the originals wouldn't be touched and copies of the originals with the new structure would be created. It's no big deal if it can't be done, but it'd be a nice feature. Thanks for your time.
Copy them first and then rename the copied ones.
