Hi.
I try to copy the titlename of 50 dj mixes to the empty albumfield.
MY songs are all in one folder. I imported them to mp3tag.
I tried to set up a new action, but: I don´t get the point.
Is there any easy help?
Thx,
MIke
Hi.
Thx,
MIke
Hi. Thanks alot.
Didn´t work.
This one:
Action type: Format value
Field: BAND
Format string: %artist%
copied the field INTERPRET to the field ALBUM-INTERPRET
I tried to chnage your tip to:
Field: TITLE
Format string: %album%
but that deleted all TITLE
What I want is the following: either the DATEINAME or TITLE -> ALBUM (either green or red arrow):
http://img2.pict.com/aa/93/4a/3316165/0/mp3.jpg
I changed mp3tag to English, but it stays partly German.
Thanks alot,
Mike
ahhhhhhh, viceversa, the fields.
Got it, thanks alot.
Mike
This copies the content of the ALBUM field to TITLE. Use ALBUM as field and %title% as format string of you want it the other way round.
If you're referring to the column names in Mp3tag's file view and the descriptions of the user-defined entries at the Tag Panel then it's by intention (since these parts could be possible changed by the user).
