When I select the button FILENAME - TAG the syntax is %title%
But this just does a direct copy.
What would the syntax be to copy just the name only, for example
01 - Song One.mp3 --> Song One
or
01 Song Two.mp3 --> Song Two
Thanks
or
Thanks
You could try this Format string:
%track% - %title%
or
%track% %title%
If you don't want to save the track number, you can also use
%dummy% instead of %track% and the number will be ignored.
That worked very well, thank you!
