Copyright is not shown
For all my music the field "Copyright" is filled, but in the lists the coloumn is empty. What do I wrong?
Could you show us the column definition and a dump of the extended tags dialogue for a file that allegedly has a filled copyright field?
This what you mean?
Thank you.
Almost perfect.
I see the contents of the extended tags dialogue and now please also show the column definition.
What I see: you have APE tags in the files but apparently you don't read them. Is that on purpose?
MP3 -2
This?
Thank you.
You need to fill in the fields for
Value (Waarde) and Field (Veld)
This would be %copyright% for both - as you show the value and you want to write that to a certain field.
Great! Thank you very much for your very quick help!
