Could extended tags (right click) show more tag fields?
Hi
when I right click on a track or many , I can select the extended tags
well could extended tags show more tags fields like codec type , bitrate ,sample rate , replaygain ?
is there a way to add these field in the extended tags?
thanks
No, there isn't.
The extended tags dialogue shows the fields that can be modified.
cannot be modified by MP3tag.
is an editable field. If you don't see it, then check the settings in Options>Tags>Mpeg which tag types you read and check the files what tag types they contain. Replaygain data is often saved in APE tags.
hi @ohrenkino
thank you
