Cover art gets not changed
Hello,
I tried to replace my cover art, but the image is not changed. I used the built-in MusicBrainz option.
Regards
Andi
In the Tag Sources dialog where the data and cover from MusicBrainz is displayed, can you make sure that "Save image to tag" is enabled when right-clicking on the cover art window?
Oh I see. This was not checked. I did not even realize there are options available. Maybe they should be moven to another place.
Unfortunately I dont get any good hits at all with Musicbrainz. Is this normal?
