Cover Art - Option to Replace
the cover does not appear when I import data tags from Discogs even when I check the box to include.
I previously checked the box "Not Replace" the cover, and now I can't find that page because I need to be able to replace incorrect covers that appear from unknown "folder.jpg" folder locations on my hardrive.
The option to set covers from web sources can be found in the Utils button menu.
