hi. i have read all topics related this and did the suggestions made by others (removed APE in both read&write) section in mpeg options but still artwork is not showing up after i hit "ctrl + s".
i mean i drag and drop art pic and it is showing but after saving the pic is get lost. it used to work but not now.
also i have a suggestion can you please add shortcuts for this actions (done under mpeg in options) to right click menu? because right now it is ridiculous to go in settings and changing actions at there. actions should be on right click menu. for example removing ape tags should be on right click menu so i wouldnt have to go and do lots of settings to simply remove ape tags from the files right? right clicking on files and selecting "remove only ape", "remove only id3v1" & "remove only id3v2" tags would perfectly work for right click menu.
