Hi @Florian Thanks for the great product. Just a note - since the v3.26 update I'm finding that 70% of the cover art I import from Discogs has a white border/frame around it, I then manually copy and paste the same artwork from Discogs and it looks ok. I'm not sure if this is meant to be happening or if it's something I can change so it imports with the frame(?) Thanks.
Thanks for the feedback! Can you point to a release on Discogs where you see this happening?
