press Alt+S, P, 1 I can confirm this is the case. Works okay, brings up the attached dialog. (see attached dialog which pops up) Latest app versions = mp3tag 2.49 and Mp3tag Cover Preview v1.4 Can you show an image of the whole caption and menus in Mp3tag? Sorry is that not what I attached the last time? Not sure what you want.
Thanks (cropped the image to the part that I needed).
So both Mp3tag and the tool are running?
Can you deselect the [ ] Top option and then click the button?
Does anything happen, like bring Mp3tag to the foreground?
What if you manually start a search and then hit the Preview button when the search results are displayed in Mp3tag?
Okay so im a little further on now, I deselected the [ ] Top option. I then manually done a search by hitting Alt+S, P, 1 to search beatport for art as my script name is Cover &Preview#&1 beatport (single)
So THEN the artwork appeared in the program (see attached) even without hitting preview! which means the script is working as it should its just the ws01 button is not pointing towards the right script file. Would this have something to do with me running mp3tag portable?
It should already search for "Cover &Preview#*.src" files in the default Mp3tag Appdata location and use these.
If you have a different location check the settings.ini file for "Mp3tagDataPath=" setting.
I've put both Mp3tagDataPath="W:\Apps (Portable)\Music Apps\Mp3tag\data" which is the path wrapped in quotes and Mp3tagDataPath=W:\Apps (Portable)\Music Apps\Mp3tag\data there and there still is no tooltip.
Is it possible to display the covers from a certain cursor position ? Unfortunately I can only display 10 titles from the first position. But if you have more than 30 titles in the selection window, this doesn't really help with the search.
I have extracted the files in the 1st zip, i have extracted the files in the second zip to the correct folder
I have run the .exe
I highlight an mp3 file in Mp3Tag and then press one of the buttons in the standalone .exe.....no pictures appear in the standalone exe, instead i get a box (list of search results) in Mp3tag that offers me the ability to preview a single image...not a strip of choices in the standalone app...just two rows of white nothingness, if i click Preview on this search results page i go to a web page...wtf?
What gives? What the heck?
Why does literally EVERY album art downloader just fail to work as easily as they sound they should, im on my 3rd now...
