If you load the playlist then the tracks will be dsiplayed in the correct order, right?
If the filename has to reflect that order you may use
$num(%_counter%,2)
which produces a two-digit number.
So a filename like
$num(%_counter%,2) - %artist% - %title%
would show the layout of playlist.
If you want to go back to your old filename then rename the files
%track% - %artist% - %title%
Yes when load a playlist in Mp3tag displayed correct.
If i use this sentence $num(%_counter%,2) - $validate($trim(%ARTIST%) - $trim(%TITLE%),)
The result is
I need in the filename, the same order of playlist.
Need this (example made with keyboard)
Thx in advance and sorry again for my bad english.
