Create combined playlist of several albums
Is it possible to simply create a combined playlist of several different albums, e.g. fast, slow, reggae
Thanks
You can create playlists for all displayed files or only the selected ones.
If you have the criteria
somewhere in the files (as tag data) you can filter for it and display only the files that match the criteria and then create a playlist from these displayed files.
that worked thanks. . . . . . . . . . . . . . . . . . . .
