Create & Export CD Cover to Jpg
#1
Is there a script to export Tracklist and create - in my case - back CD covers?
A lot of digital meadia comes without back covers - i would like to smply export the album info and create back covers.
If it sdpes more creat but i need a simple Black & white cover.
thankas
#2
I am sure, the forum has a bench of export scripts, which can create a simple cover print out as of type TXT or RTF or HTML.
For example ... user "Gabor" has worked out some scripts ...
https://forums.mp3tag.de/index.php?act=Sear...mp;highlite=%2B
Once you have a text print out file, then you may apply Irfanview to convert it to PNG or JPG format.
DD.20170526.2042.CEST, DD.20170527.1030.CEST
