Hello friends, when creating a playlist, is it possible to change the playlist extension to mp3 or wav instead of m3u, thank you for your help.
A playlist is a file for which you can change the extension to anything you like
As shown in the picture, the m3u extension does not work in applications such as sam2. This does not work when you change it to m3u - mp3 or wav.
I don't see a picture.
I would use the singular "application". I know several applications that work with m3u playlists, e.g. iTunes, Windows Media Player, Foobar2000, VLC, MediaMonkey, Musicbee ...
So please check if your player supports playlists.
Renaming a plain text format to a digital audio format that has to follow certain standards will probably cause other problems with decent players.
