Creating Directories
Hi there, I want to change my directory naming scheme but I have too many to change it manually.
I'm sure there must be a way in mp3tag to do this, I simply want to change or create a directory according to the song/album tags.
%artist% - %album% for example.
Any ideas? :slight_smile:
Many thanks
"Convert > Tag - filename" with format string:
%artist% - %album%\%_filename%
creates a new folder.
Sweet, thanks :slight_smile:
I guess there's no way of making it rename the existing folder?
There is. /t/6126/1
I love you, thanks mate :slight_smile:
