Is it possible? F’rinstance: I change out Album Art, and I’d love to assign Ctrl+B (I believe it’s currently Unused) to do the mouse action of Tag Sources → Cover Art → Discogs Artist & Album.
I don’t know nothing about programming, but I’ve seen Keyboard Shortcut augmentation pages in other platforms. I was hoping it could be done here- I’ve got another 800 or so bands that need cover art added/changed.
This is not possible with a 2-key combination. There is the possibility of having shortcuts in the sources menue. The third part of the key-combination is defined by the letter with an underscore.
By renaming the actions or websources you have influence on the key.
Get@Cover as a name would underline the C in the menue and you could press
ALT-S-C
to call that websource.
Perhaps CTRL-i helps you. This shortcuts calls the last called websource.
