Creating Playlists based on Genre when there is more than one Genre
I am using version 3.25 and have some music files with multiple genres such as
Soundtrack\\Pop
Soundtrack\\Rock
Soundtrack\\Score
Is it possible to adjust the settings so the the second genre is picked up instead of the first? Thank you for taking a look at this.
Playlist Generator
For the second genre, you could try it with
$meta(GENRE,1).m3u
From the documentation:
BTW:
The first genre would be $meta(GENRE,0).m3u but this would be the same as %GENRE%.m3u
That works perfectly. Thank you very much!
