Creation Lyrics Field
I wanted to create item in Custom List Values and place a Lyrics field in the Tag Panel, but I couldn't find Lyrics in the Dropdown Field. Can you help me?
The field you are looking for is called UNSYNCEDLYRICS
In the above example I chose the same Name, but you can call the field in the Tag Panel "MyLyrics" or whatever you wish.
Thanks very much. Thank you for the quick reply.
Thanks very much :ok_hand: :ok_hand: :ok_hand: :ok_hand: :ok_hand:
