CTRL+N does not save the changes
Hi, I’ve installed the latest version v3.31 x64 for Windows.
The function CTRL+N does not save the changes in my tags, only possible with CTRL+S.
Why is this function disappeared?
Yes. This has been so and still is - see the documentation on keyboard shortcuts.
Ctrl-N goes to the next file. Unless specified otherwse, going to the next file saves the modifications.
Depending on the message settings you get a message about unsaved changes.
I’ve installed back the previous version v3.30 and it works again as before, please check your new version, it has a bug.
Thanks for pointing! This is an unintentional regression from the previous version, which unfortunately wasn't spotted in the beta period.
I'll look into it.
I've just released Mp3tag v3.31a, which should fix the issue where changing the selection via dedicated keyboard shortcuts didn't save changes.
Thanks again for reporting!
