Cue sheets playlist
Hello,
First off, great peice of software guys, I love having embedded artwork etc, awesome.
Edit
Can I embed cue sheets with mp3tag? how do I add the cue sheet to my file. I need this for my mixed CDs.
I did a little search on the forum and couldn't find anything.
Please help.
Thanks
Andrew
i don't think this feature is available. sorry.
Depends on where you want your cuesheets to be stored. If you want to import them to a custom tag field like CUESHEET you can simply use the :mt_tag: Extended Tags dialog via [Alt+T].
Alternatively, the latest Development Build provides an action type Import text file which allows for batch import of text files (e.g. cuesheets) to a given tag field.
Kind regards,
Florian
