Custom Action Help
Hi everyone having a problem figuring out how to do this. I have a file that is named:
14.Ol Dirty Bastard - Lyrical Virus - MVP.mp3
I want to create an action that will remove " - MVP"
So the end result would look like this:
14.Ol Dirty Bastard - Lyrical Virus.mp3
But I can't make it work. I went into actions and made this action:
Replace "_FILENAME": "- MVP.mp3" -> ".mp3"
but it isn't working...what am I doing incorrectly?
thanks in advance :slight_smile:
You can't use the file extension at the Replace action type. Just replace "- MVP" by nothing. If you really need to replace the file extension, you can use the action type Replace with regular expression.
Best regards,
~ Florian
Florian thanks that fixed it.
By far the best and most feature packed filenamer out there! :laughing:
