Hello there,
I have an action which forces uppercase on tags.
Now I am wondering if there is a way to force exact case for bank names which have specific capitalisation. For example, 'InMe' instead of 'INME' or 'inme'.
I know you prefer plain English descriptions, so I include the key which states what everything means within the code, which I created back in July 18.
T=Action
T=1 'Case conversion'
T=2 'Replace'
T=3 Not listed in action types
T=4 'Regular expression'
T=5 'Format value'
T=6 'Remove duplicate fields'
T=7 'Guess values'
T=8 'Merge duplicate fields'
T=9 'Remove fields'
T=10 'Remove fields except'
T=11 'Convert codepage'
T=12 'Import cover from file'
T=13 'Export cover to file'
T=14 'Import text file'
T=15 'Export'
T=16 'Split field by seperator'
F=Field
1=Original string
2=Replace original string with
3=0 Means 'only as whole word' and 'case-sensitive comparison' not selected
3=1|0 Means 'only as whole word' selected and 'case-sensitive comparison' not selected
3=0|1 Means 'only as whole word' not selected and 'case-sensitive comparison' selected
3=1|1 Means 'only as whole word' selected and 'case-sensitive comparison' selected
Existing forcing uppercase:
! Artist UPPERCASE Conversion List (Initiate)=
[#67]
T=5
! Artist and Band UPPERCASE Conversion (Start)=
F=ARTIST_LIST
1=abba|adda|absrdst|acdc|ac dc|akdong musician|bkpr|blk jks|bts|chllngr|chvrches|chll pll|dfrnt|diiv|dmc|dnce|drwn|dtcv|dwntwn|dvsn|dvsr|exo-k|grmln|haim|htrk|hxlt|inxs|jmsn|jpnsgrls|kaytranada|kda|kshmr|ladybaby|lany|lee hi|lndn drgs|lnzndrf|lvthn|mgmt|mika|mnek|mndrmnek|ms mr|mstrkrft|n sync|nsync|partynextdoor|pwr bttm|pza|rdgldgrn|rkcb|rlyr|r\u00dcf\u00dcs du sol|rvivr|ry x|sbtrkt|shxcxchcxsh|sophie|stnnng|strfkr|swmrs|tnght|tr/st|tts|tstr|walk the moon|wzrd|u2|u-kiss|unkle|wstrn|xtrmst|zayn
[#68]
T=4
F=_ALL
1=$regexp(%_all%,(?i)\\b(%artist_list%)\\b,\\U$1\\E)
2=
3=0
[#69]
T=9
! Artist UPPERCASE Conversion List (End and Delete)=
F=ARTIST_LIST
I hope you can help, thank you in advance.
