Custom Tag Sources does not work because of security reason
I started to try the new support for Custom Tag Sources for Mac. But it always appears the error message: The resource could not be loaded because the App Transport Security policy requires the use of a secure connection.
Does anyone have a solution or hint for me?
Best wishes, jcweb
It's probably a tag source that is using HTTP instead of HTTPS — the latter is required to be used by Mp3tag.
Can you point to the respective tag source and maybe even try replacing all occurrences of http:// by https:// in the *.src file?
That's it. Thanks a lot.
