Hi Florian,
great work and great program, helped me a lot to edit 2000 songs last evening.
Something what occurred to me during last edit. It would be nice to have:
- There is no overview of non standard (Custom Tags). Because there could be any custom tags inside of. e.g. 1000 songs, there is no way to easily find them. It would be helpful in order to decide which columns to add.
Addition of this columns with Custom tags should be easier (a selection from available from current songs).
Added custom fields should become a selection for Tag Panel - adding those custom fields should be easier. Same for filter (currently it is not possible to filter by values in custom tags).
Missing option - Convert Tag-Tag (e.g. simple copy from Custom Tag to Comment, etc.)
Additionally,
4.1. Filters still do not work properly with such characters as ()[], which were used extensively in file names. Same with those characters in "Convert" Filename-Tag. Funny that it works in converting FileName-Filename (so I had to use this option first to replace all ()[] in the file name by e.g. 'zz', and than using conversion to replace what was in between 'zz' and 'zz' to get this info into the tag. This characters should be handled correctly on all levels.
4.2. Error message if, e.g. Edit file names of 2 files which contain
1st file format: %1--%2--%3
2nd file format: %1--%2
I give a command to replace %1--%2 with %1-%2
On the first run everything is fine.
On the second run, an error message pops up.
Works only if. the refresh of the page is done, files selected again, applied editing tool.
4.3. Was missing an option to remove spaces in the end of the name: e.g. "Song Name .mp3"
4.4. Would be nice to move columns by drag and drop.
4.5. Option to delete all ID3v1. Option to write only to ID3v2
4.6. Advanced filter with multiple conditions. Though, a trick works - advance filter in MediaMonkey, drag and drop selected songs to Mp3Tag Editor. But, again, no option to filter by custom tags, or option to filter by "begins with" & "ends with" even there.
Thank you very much for a great help which your program gives to all of us.
Regards.
