Im DJ CHARGE and im Using Serato for my Music Stuff and Library Management. I dont like the fact in Serato that u cannot add multiple Custom Tags like in Rekordbox.
I used the comment field for my custom tags so this can look like this
Artist: Beyonce
Trackname: Single Ladies
BPM: 105
Genre: Dancehall Comment: BIG ROOM - LADIES - PRIMETIME - SAFER
So this ist how I Tag my Songs. But for better search i need to put a [ ] for every Tag in the comment
Example: [BIG ROOM] [LADIES] [PRIMETIME] [SAFER]
Some Tracks have diffrent and other tags like here in the picture.
Is it possible to add [ ] before every word ?
Sorry guys my english is so bad i hope you understand what i need.
I consider it as very redundant: if you enclose the terms (which I assume should be the result) in brackets - why do you still need the hypen? This only adds 2 more characters to the whole string (space and hyphen).
I think you could get rid of these without any loss of information.
Which brings me to another approach - perhaps with 2 actions:
First: a simple replace where you replace all "space hyphen space" with "] [".
Than one of the type "Format value" for COMMENT with
Format string: '['%comment%']'
I noticed a "BIG ROOM" and "BIGROOM". Did not find the same kind of inconsistency with any of the other two-word comments, but we are presented a small sample of what is probably a large library. It would be a good idea to search for two-word comments both ways and resolve the inconsistencies that are found before trying to bracket the comments.
I suspect that the bracket desire is to prevent finding a search term in an artist or title by mistake.
