I'm a new user to Mp3tag and am using 2.36a. So far I really like what I'm finding and will undoubtedly continue to use the program.
BUT, I do have a problem.
I have managed to add some columns for which you had the codes listed in your help files. However, I am trying to add 2 totally new types of columns. One which uses @ to tell me that I have confirmed all of the info in that record to ensure its accuracy. The other uses VA to let me know that this particular file comes from a compilation of Various Artists. (In this way I leave the Artist column free for the actual artist. This is where I have run into a brick wall.
View- Customize Columns
VAlue: %fieldname%
Field:
Sort by:
According to the instructions you need to have a placeholder in the Field slot but no matter what I try, when I enter the VA later it disappears as soon as I hit . What am I doing wrong? I have tried to explain this fully but if I only ended up in confusing the issue please let me know.
I should also explain that I was a tech for many years and working with this kind of stuff use to be very intuitive for me. The effects of a stroke have seriously changed that and sometimes the simplest thing end up looking like Latin to me. So please make any explanations detailed and very clear.
FreekRPG
