Dark mode issues
Hello, I like dark mode, but it has some minor issues:
  • few icons have a white border, save, delete, play (same delete icon is without white border in Options - Export)
  • triangle icons are black, bad visible
  • white line et the end of toolbar
  • white dot in the status bar
  • background color for menu, main toolbar and the color next to them are different
Could you improve it, please? At least those icons, other icons are OK, just those few icons looks not good.
Mp3Tag v3.18 64-bit portable, Windows 10 21H1 64-bit.
was the top Title Bar always dark for you in your version of Win 10? Using any version of Mp3tag that supports dark mode seems to always give me a white title bar instead which does not seem to be unique to Mp3tag but I can’t find the common thread. I used a registry workaround to fix this on Win 10 1903 x64, but wondering if this issue gets resolved in newer versions?
If you mean the title bar, first line of the window, I changed it to dark manually in Windows Settings, no registry hack.
