delete tracknumber out of artistdiscription
In the Artistname the tracknumber is included. Is there a way to delete this part by using a Tag or Function?
Greetzzz
Bob
yes.
and if you could tell us more about the construction of the artistname then I could be more specific about the help.
Try an action of the type "Replace" and replace \d+ with nothing.
But this would probably also reduce "001 - Blink 182" to "- Blink"...
