Strange things are happening here...I think
I've tried tagging a few FLAC files with comments & descriptions. Using the default fields / mappings available in mp3tag)
When both those fields are tagged only the description appears in my music player, oddly enough the description is seen as a description AND the comment, seemingly overwriting the original comment.
Tagging a FLAC or OPUS file with just description or just comment has no issues, the information is parsed by the music player perfectly in both those scenarios.
This phenomenon of overwritten tags is not present for MP4 MP3 or WAV files (from my testing). Is there something I am doing incorrectly or misunderstanding? Is there no way to have both a comment & description (separately) on a file tagged via Vorbis Comment, or must I cast my dreams into the wind?
I'e attached images to show how I tagged the file & how it was seen by Symfonium (android music player) I originally thought this was an issue from the player itself, this was the devs response:
"So seems MP3Tag also set the description as the xiph comment leading to overwrite of the comment field. Will priorise the actual tags over the xiph comment as it’s more explicit anyway."
