I set in Options-->Tags--->Mpeg--->Remove
ID3v1=YES
ID3v2.3=NO
Now I mark a couple of songs and right click on them
In the context menu appears
"Tag Cut" and "Tag remove"
whats the difference?
Which one deletes the ID3v1 header (ONLY)?
ID3v1=YES
ID3v2.3=NO
"Tag cut" copy/cut the tags of the selected tracks to the clipboard. This is useful, if you want to paste it back to the tracks in a next step.
"Tag remove" deletes/removes the tags of the selected tracks, without the possibility to paste it back.
