Hi
I found out that if you search for one album you get different resutls for the style.
So how can I avoid this confusing results?
thanks
Hi
thanks
That is because there is no standard for assigning a certain style - it is very much down to the personal taste of the one who entered the data.
Also, it looks plausible to me that an artist knows how to play music in different styles and not just a single one.
The same variation applies to GENRE.
If you want to set a single STYLE to a set of files then select the files in MP3tag,
open the extended tags dialogue (Alt-T)
edit the field STYLE
enter the value of your liking
Click OK until all dialogues are closed.
