Help. I use to have the directory listed in my columns showing the directory and folder where the particular file was located. I've just noted it's no longer listed. Could someone please help me in restoring the Directory listing in my columns?
Thank you very much.
You get a list of all current column definitions if you right-click on any column header and then click on the function "columns ..."
Check the list of column definitions whether the missing column is not ticked and if that is the case, tick it.
If the column definition is missing also, then create a new column (new button) and enter as value %_path%.
If you have accidently narrowed the column too much look for a column where you can see only a single letter and double click on the right border to the next column header.
