Directory creation using multiple artists
In some of my albums, there are multiples artists and I've decided to properly tag them. I have two issues about this and I'm creating two separate threads.
When I'm done with all the tagging, I ran an action that allows me to rename the folder where my album is located: Format value DIRECTORY": %artist% - %album%.
My problem is that, if there are multiple artists, only the first one is used.
I'd be very happy if there was a way to use all the ARTIST tags where creating the name of the directory, so that my folder name looked like this:
artist 1 & artist 2 - album
artist 1, artist 2 & artist 3 - album
The ampersand to separate the last and the second to last elements would be an appreciated bonus, but not strictly necessary.
Thank you for your help!
Use
$regexp($meta_sep(artist,', '),'(.*), (.*)',$1 & $2) - %album%
Thanks for this too! It's amazing to see what you can do with this programme when you know the language.
You've been very kind and also very quick to respond,@ohrenkino
