Is there a way to clear the directory list dropdown box in the tag panel?
Delete/rename mp3tag.cfg
This removes a couple of other settings as well ... so perhaps not the ideal solution.
I assume it works like the other dropdown lists in Mp3tag, ...
press [Shift]+[Del] for each entry within the list.
DD.20150603.1848.CEST
Unfortunately, that does not work.
