Is there any way to disable Mp3tag from playing an .mp3 file after I double click on it within the program? I double-click on a value field to edit it, and unless I click in the exact right spot, I end up accidentally opening the file, and I do it ALL the time. I can't find any option in the settings to avoid this. If it's not possible, can anybody give me a tip on how to edit a specific field quickly (besides using multiple keyboard strokes)?
You can go to File->Options->Tools, activate "Use special program at double clicks" and select "No action".
If you anyway want to play a file, you can use a "right-mouse-click" and select "Play.".
