Am more than likely over thinking this which is why I am unable to sort it out on my own...
I am able to create Multi Disc folders without issue and Format Disc Numbers to 2 digits as required however here is the issue I now face.
I have a number of Box sets where secondary discs are in a word format or are numbered and worded...Examples:
CD1: Main Album
CD2: Remix Album
Bonus Disc
XXL Download
and
5'' Vinyl
Download Cascade 1 (Wüterich Beatel)
Download Cascade 2 (Wüterich Floating)
Download Cascade 3 (Wüterich Instrumental)
I would like to be able to create/maintain these folders and their respective names but how do I do this? Am I needing to use a user defined field and than do something like:
Format Value: _Filename>Disc %discnumber%%USERDEFINED FIELD%\%_filename_ext%
or is there a way to check to see:
if %discnumber% is a only a number than format $num(%discnumber%,2) or
if it is a number and a word than do the same formatting whilst maintaining the word value
if it is simply a word maintain that as the field
Then create subsequent disc folders?
I recall seeing something similar to this on the forum recently but do not remember what the Topic Title was and am unable to locate it now...
Any assistance would be appreciated.
