Disc number / Part of set tag and delete feature
Could it be possible to add the 'Disc number' / 'Part of set' tag to Mp3tag? In my opinion, this is the most convenient way to deal with multidisc sets (double albums, boxed sets and so on).
Also, I accidently deleted more than 10 CDs when hitting the Delete key by mistake. You really should enable the 'Show message when deleting files' option by default!
Olivier
Olivier,
you can add user-defined tags via the View, Tags ... menu with the latest development.
I'll enable the delete message box by default to the next release. In the meanwhile, you can have a look at your Recycle Bin. Maybe you'll find your lost albums there.
Best regards,
~ Florian
Thanks. I've already restored everything I could from the recycle bin. That's why I "only" lost what I lost. :slight_smile:
Olivier
BTW, when you say "latest development", you mean the next version of Mp3tag, right?
Olivier
Yes - but you can already try the new features with the latest Development Build.
Please read the changelog carefully, because there are some major changes :slight_smile:
Best regards,
~ Florian
Best regards,
~ Florian
Ok, great!
Thanks,
Olivier
