Hi, in the header of the list there is unnecessary "&" character in the title of the Discnumber column (Číslo &disku).
PS: I'm also missing some pre-defined entries like 'Symphonic Metal' or 'Industrial Metal' in the Genre textbox.
Thanks for pointing. I'll correct it to the next release, you'd have to edit this for yourself via View → Columns...
User-defined Genres can be added via Options → Genres (v3.19) or Options → Tag Panel → Genre → Custom List Values (v3.19+)
Thank you for the tip on quick fix.
