Moin Moin,
I just have a simple question with regards to DISCOGS and APP authorisation. I have read on the DISCOGS site that once the APP is authorised there is not further authorisation required.
Now why is DISCOGS asking me after a X-Number of TAG look-ups to re-authorise MP3TAG?
It is no biggy or annoying but I was just wondering?
Hello Florian,
no it is always the same notebook. Is it possible that CCleaner could remove it? I guess the token is system specific and does not bother with IP addresses etc
I can not think of anything else, I run CCleaner regular to clean crap out and I have currently a very unstable connection. - That is all I can think of ..
Nope, no manual system time changes. System is set to do that whenever it does its checks and this should not be significant ..
I just checked it and it is with today's auth, the 5st time since March 25. That is when I start using MP3TAG again to manually clean a section of my collection.
MP3TAG is installed as is, I do no think I have made any config changes after the installation or during the time I have been using it. The only thing I do, before I shutdown I run CCleaner to clear out cookies etc ..
It does not bother me, I was just curious and thought I ask. I will see if I can work out what I am doing to make this happen.
it seems the authentication issue is system time related, I still do not know yet as to why. If the authentication request pops up and I then manually sync the system I can continue to work under the original auth-code. The system logs clean - no errors - no warnings and the time difference cannot be more then seconds. I will go and buy/order a new system-board-batterie for the notebook as it around 6 years old, if that does not fix it I will need to reinstall.
Nothing is worse then to know how to workaround a problem but not be able to fix it!
